30-07-2025 01:14 AM
I am going on holiday to Turkey next month for 2 weeks and wondering if I can use my phone abroad. Last time I was there I was with O2 and I was charged a fortune daily. Just wondering with EE will it be the same? Or are there any add ons/packages you can pay for to use your phone?
all help appreciated 🙂
30-07-2025 01:58 AM
@Hannahmc28 : If you are on contract, you may use your usual UK allowances in the EE ROW Zone 1 with up to 50 GB data per billing month if you have more, when you buy the Zone 1 Pass for £5 / day or £25 / week or already have it as an Inclusive Extra or you have an EE Full Works or EE Max Plan. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/turkeyandnortherncyprus.
If you are on contract, just remember to text ROAMING to 150 before leaving UK to ensure the roaming ability is enabled on your no.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
30-07-2025 01:58 AM
