24-05-2025 09:10 PM
Travelling in few days to India. Enabled Roaming by texting 150.
reply says all set for roaming in India.
It’s reads text will be send when India, also it reads, ‘ You will not have access to mobile data unless you by a pass’
how does it work, if the text comes with a link to buy travel pass? without mobile data access?
also, how it works to buy for 12 days, can one buy 7 days and 5 single days at the same time.
it will be helpful, EE Roaming page give more detail https://ee.co.uk/mobile/international/travel-data-pass
really appreciate if anyone used or have information could share their experience please.
24-05-2025 09:38 PM - edited 24-05-2025 09:41 PM
If you are on contract, you may use your usual UK allowances in the EE ROW Zone 2 with up to 50 GB data per billing month if you have more, when you buy the Zone 2 Pass for £7.50 / day or £37.50 / week. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/india.
In your case it'll be cheaper to buy 2 x 1 week passes in succession.
24-05-2025 09:13 PM
Providing you have enabled the free roaming facility, this allows your SIM access to foreign networks - which unlocks the ability to get coverage and consequently make & receive calls, send & receive text messages.
By design, you will be able to connect to links within EE's core network in order to purchase add-ons and suchlike - once add-ons are in-place, that access will be unlocked for full internet access.
You can only have one add-on in-place at a time, you will have to choose between (5x1) + 7 or vice-versa - and purchase them in that order. When one expires, purchase the next one.
24-05-2025 09:47 PM
Thank you both for your quick reply
24-05-2025 09:49 PM
