Data
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-07-2024 10:43 PM
I've just arrived in Turkey and am getting no 5g, 4g etc. Any ideas?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-07-2024 11:00 PM
