Data roaming
mgfvvcjl01
Do I need to switch data roaming on whilst using my 7 day pass
Northerner
Hi @mgfvvcjl01
If you're on a pay monthly plan then unless you have activated roaming on your account then it is likely. Text ROAMING to 150.
If on PAYG you activated in the UK , then it should be enabled automatically.
Northerner
Hi @mgfvvcjl01
Michael_D
Hi @mgfvvcjl01
Once you have roaming set up and an add-on in place, you will need to have data roaming switched on in your phone settings to be able to use your data allowance.
Michael
Only if you want to use data while away. If you just make calls & texts, there's no need.
