Data roaming isn’t working and I have it as a add on with my package
Mandersclo1985
I have a data roam pass as an add on within my package, I got to Turkey and it isn’t working can someone help I need to be able to receive calls and text messages
You're probably referring to the "Roam Abroad" pass which is not a data-specific add-on, but allows use of your voice, text & data allowances within the EU. But regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks.
The Roam Abroad Pass is not valid for Turkey, Beyond that your symptoms are indicative of roaming not being enabled on your a/c as described by @bristolian .
