Data roaming abroad
Nige18
Why dosent my data roaming work abroad ?
@Nige18 : Can you make calls & texts?
Does your phone show a mobile network connection abroad?
Can you voice roam, and make or receive calls? Can you text roam, sending or receiving texts?
