Calls from NZ to UK can't be made.
APVaslet3
I'm on holiday in New Zealand and need to call my UK bank from my UK EE number. When I call any UK number I get an automated message saying "You can't make call right now as you've put a call bar on, you'll need to switch this off."
I'm on a monthly contract, with a 20£ spend cap and a the international 30 min call add on. Can someone please explain why I can't get through?
Cheers
7 REPLIES 7
@APVaslet3 : Can you receive calls & send texts?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
1; Can you call NZ numbers? Which is another way of asking whether your phone has a connection to any Kiwi networks.
2: Did you receive a welcome text message on first arrival in NZ?
3: Is the automated message in an NZ or UK accent?
I have this exact problem.
1) can’t call NZ numbers
2) have received a welcome message, also receiving texts and using data works fine
3) message is in a kiwi accent
My EE line has previously worked absolutely fine in NZ, this is a recent change.
any help would be appreciated. Thanks
Normally "me too" posts are best moved to a new thread, but you've provided enough detail to conclude roaming is already enabled and your issue may be resolved by performing a manual network search and cycling through each local network in turn.
Are the symptoms the same on each? Or does a particular network resolve the issue?
Oops, sorry. Just seemed to match my exact problem so tagged in. At least it’s not a Harvey Weinstein kind of ‘me too’!
Thanks for the input. My phone connects successfully to Spark NZ, but calls are barred. The other two networks - One and 2degrees - I can select but the phone won’t connect, ie no signal bars. Previously (before EE changed roaming from EU and RoW combined to separating them), I could select any network and it would work fine.
no idea what’s going on here! Thanks for the help trying to work it out. What shall I try next?
thanks!
T
@timk86 : Just to clarify: EU & ROW 1 roaming were never combined. It used to be that EU + 5 non-EU countries, incl. NZ, (a small subset of ROW 1) were combined under the Roam Abroad Pass.
Yes, thanks. I meant that specifically referring to NZ
