Australia Roaming
Posted in the open:
@lizzyo60 wrote:
Having landed in Australia I’ve bought an ee add on which will allow me to use my home data messages calls etc but it’s not connecting. There’s nothing on my setting which says turn on data roaming. I also runs an Airolo eSIM but even when I turn that off there’s still no 4g signal
8 REPLIES 8
lizzyo60
I’m having the same issue! Bought a roaming add on but it’s not connecting and not getting any info from ee at all. It’s just saying make sure data roaming is turned off in but nowhere on my setting does anything say turn in data roaming. Jet lagged and my brain is fried
@lizzyo60 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Nor is it anything to do with data roaming settings. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
lizzyo60
Hi
I definitely have roaming activated in my phone as I travel a lot. I’ve tried rebooting. Also there’s no list of networks. As I have an eSIM running too this seems to negate any mention of turn on data roaming on the device
Thanks for the help tho I’ll contact ee when the timings are better. My husband has the roam abroad feature constantly and has connected no problem.
Thanks Liz
Sent from my iPhone
Who's talking about your phone? It's nowt to do with it. I told you that it's whether you activated roaming on your EE account by texting ROAMING to 150 in UK.
Roaming is not a phone setting, it's an account/SIM one.
The phone setting you're likely thinking of, is "data roaming" - this simply allows use of mobile data whilst already roaming.
This is all regardless of physical SIM or electronic SIM, which makes no difference.
If you perform a manual network search, and are saying no networks are found - there's your problem.
lizzyo60
Hi
I’m in the centre of Melbourne Australia so I know there’s definitely network’s available, my husband is with ee and his is working fine. I’ve managed to get an eSIM from airolo to work but the addon from ee is not showing anywhere
Liz
Sent from my iPhone
lizzyo60
Hi
Yes the phone is definitely activated and I got the reply saying is activated. I travel a lot and was in Africa recently and it worked there no problem. It seems to be since they dropped the £25 a month Roam Abroad option on December 4th
Liz
Sent from my iPhone
Katie_J
Hi @lizzyo60
If the add-on is not showing on your account I would recommend switching your flight mode off and on, this should trigger a welcome text with the link to purchase the add-on.
Could you please try this and let us know how you get on?
Speak soon,
Katie
