Add-on not working while abroad
JulieP1967
I am abroad in Morocco and purchased an add on but I cannot make or receive calls I cannot even call EE and speak to anyone for help
[Mod edit: Added title]
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
