Viptalk01
Iosifafan07
Im trying to send “VIPTALK01” to 150 but its doesnt reply to me when I send that, however it works with every other command
That's a v. old legacy pack. EE has probably now withdrawn it. You'll have to switch to 1 of the current packs listed by texting ALL PACKS to 150.
9 REPLIES 9
Where have you seen this command referenced?
It's not one I'm familiar with, but have you seen it mentioned somewhere or part of instructions?
It used to be called TALK01 its the 1 pound talk and text pack but it isn’t available on new sims
Ritu_D
Hi @Iosifafan07
Could you text ALLPACKS to 150 you should then receive a text back with information about all the packs available.
Let me know how you get on.
Ritu
It gives the options for 10, 15 20 pound packs but says at the top of I want to purchase the same pack I should text “VIPTALK01” but right now when I text it I just don’t get any reply
Ritu_D
Could I just double check @Iosifafan07 have you used this pack before and if so when was the last time you used it?
I use it weekly but today it just stopped working idk why every week it automatically resets and takes a pound out of my credit
Ritu_D
Thanks for confirming that @Iosifafan07
Could you try texting NOW to 150 and see if this activates the pack.
Ritu
IVE tried that it doesn’t
