Strange problem with my sim card
cannonski
I have a PAYG EE Sim which is behaving strangely. I can't dial 150 from it, can't receive calls or texts. I can however make calls to other phone numbers.
I've read some forum posts that say my sim might be hibernated. Is there any way I can tell for sure, and if so, what can I do about it.
7 REPLIES 7
@cannonski : When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
However if it were hibernated you wouldn't be able to make calls.
Not sure, maybe a couple of months, around that sort of timeframe.
What does texting AL to 150 from it fully report verbatim (it is free)?
It just says 'failed to send message'. I've tried it on two different phones with the same result.
James_B
EE Community Manager
Hi @cannonski,
Our Customer Care Team will be happy to check the status of your account if you get in touch.
Ok thanks, I will give that a shot.
James_B
No problem @cannonski 🙂
