Roaming
Sillywing
I have access to Roaming 7 days but I can’t to use my date like home .
@Sillywing : Had you used that PAYG SIM for making calls or texts in UK before you left to go abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
Do you have an active pack?
