on 19-06-2024 06:10 PM
Hello, could i use add on unlimited with the 5£ pack?
Solved! Go to Solution.
19-06-2024 06:50 PM - edited 19-06-2024 07:08 PM
No, @VladyslavLG , You can only get the unlimited data when you have a pack of £10 or more. As well as what @Chris_B told you about the 25GB pm limit when roaming on PAYG.
on 19-06-2024 06:25 PM
@VladyslavLG I assume that add on is for unlimited data, if it is yes you can use it but you can only use 25Gb of data per month when roaming with PAYG in the EU.
