03-02-2022 06:09 PM
I work outside UK and it is difficult to maintain a permanent number as every time my account get suspended. The last time I couldn’t travel to UK because of Covid and I don’t want to pay unnecessary as I was not planning to travel. Now last month when I travelled they suspended that number too. Now I have new number, is there a plan where I can retain my number by paying a fixed amount in a year. Please reply, we need to need to have a work around instead of paying every month £15 just to retain the number.
03-02-2022 06:42 PM
@Enablerz To retain the number you need to make a chargeable call or text every 3 months. That’s all you can do to retain the number, topping up doesn’t do that. There isn’t an infinite number of phone numbers so if it’s not used for 3 months it goes in the Hibernation then you get three months to contact customer services to get it reactivated so you can retain that number, if you do not do that after this period of time the Sim card so it is fully deactivated and cannot be reactivated and the number then gets recycled to be used by somebody else.
Basically use it or loose it
03-02-2022 06:44 PM - edited 03-02-2022 06:45 PM
This has nowt to do with the thread you latched onto about the temporary glitch with contract roaming being suspended.
@Enablerz : It sounds like you are on a £15 PAYG Pack but your SIM keeps going into hibernation due long periods of non-use.
Yes, any contract SIM-Only will do this for you, which you never cancel & keep paying on time each month.
