Help with PAYG please
Nade9
Hi, could u please help. I would like a standard no frills SIM card which has nothing but the calling credit on it which I will put on as and when needed. I don’t need anything which will take any of my credit, if I put a tenner on I want a tenner left please. I don’t need web or texts just the phone for emergency calls. Any help would be appreciated. This phone is literally just used to receive calls from a falls alarm. Thanks
All EE PAYG SIMs come primed with a recurring Pack of allowances ready to bought out of your PAYG credit as soon as it is sufficient.
Text STOP PACK to 150 before you 1st top-up & you can use the SIM for calls & texts but not data as normal PAYG at standard per-unit rates paid for out of your standing PAYG credit balance.
To save the SIM going into hibernation due to lack of use, just remember within every 179 days (~ 6 months) to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from any Pack or Add-on you might have.
