phone too old to be unlocked
pugman227227
Valued Contributor
Valued Contributor
So I have this old Motorola flip, and it's locked to orange UK. so I requested an unlock code on the EE website and it made me enter extra info and stuff. I then received an email saying that they cannot unlock the phone due to the age of the device. Is there any other way I could possibly get it unlocked?
13 REPLIES 13
@pugman227227 You could try searching eBay for someone who unlocks phones.   There’s a few on there. Even if they don’t advertise that phone you can always just message that seller asking if they can help with that device.
right how do I know if they are legit? and how do they even work?
Northerner
Hi @pugman227227
Look at the reviews.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
@pugman227227  They work by you sending them the device IMEI number that you get via typing in to the device dial keypad.   The code you need to enter is *#06# to get the IMEI that you send them.
just asked one of them and they said could not unlock it so i think there is no fix
Do you think maybe the phone is blacklisted or something? I have asked several sellers now and they've had zero luck getting an unlock code
Leanne_T
Hi @pugman227227
If you call our mobile guides on 0800 956 6000 from any phone, they can get this looked into for you for any network blocks and also the unlocking request 🙂
Thanks, so are they able to try and unlock it or are is the phone too old as I was told via email?
Leanne_T
Hi @pugman227227
They will check the IMEI and let you know if this can be completed for you.
