on 16-08-2025 07:18 PM
Hi, is there a web chat to help me get the MCK code, I've tried to unlock my phone but the Network unlock code i was given when entering the IMEI...the unlock code didn't work...now it's saying too many incorrect attempts and is asking to Enter MCK. Any help would be grate.
Solved! Go to Solution.
on 16-08-2025 07:28 PM
@Bonny_lad : If you need the MCK code, please try the below steps using the device keypad.
on 19-08-2025 10:27 AM
That's not working 😞
on 19-08-2025 10:29 AM
so it would be 8371968 and the the 1st 8 afterwards? (Tried that and it didn't work)
on 19-08-2025 02:43 PM
Hey @Bonny_lad.
Welcome to the EE Community!
What model of phone is it you're looking to unlock here?
Peter
on 19-08-2025 05:19 PM
Samsung Galaxy A10
on 19-08-2025 06:28 PM
Cheers, when you've pasted the number in above, you seem to be down a character; this should be 83719686.
That's the one you need for the MCK code, then the next code you need is the first 8 digits of the number you shared above.
Peter
on 19-08-2025 07:05 PM
I've tried doing that (unlocking for the MCK) but what you suggested hasn't worked.
on 19-08-2025 08:13 PM
I've typed in 8371968639616837 & then tapped 'Unlock' but it says 'Incorrect network unlock code entered'
on 20-08-2025 08:36 AM
Thanks @Bonny_lad.
I'd recommend reaching out to our team. They will be able to take a closer look at what's happening when you're trying to complete this on your phone, and help further.
Debbie
