LTE plan
Lewisbaglietto
Hi, i want to add a Samsung ultra watch to my plan and be able to make and recieve calls when my phone isnt nearby (same number) I dont know how to find out if I have an LTE plan? Or if I definitely need one to connect to my phone? Please help 🙏
Ali_A
Hi @Lewisbaglietto
You can purchase a Samsung Watch LTE from EE which connect with your existing EE mobile and allow you to make calls away from your phone at Samsung Galaxy Smart Watches | EE
If you already have a Samsung LTE Smart Watch you'll just need a data plan for the watch. With a mobile data connection on your smartwatch, you can make and receive phone calls, reply to messages, get alerts and more – even while you’re away from your phone.
There are two options available:
For a free EE data plan for your smartwatch, you'll need
- an LTE/Mobile-data Samsung watch that you have purchased SIM free from EE Smart Tech or have bought elsewhere
- to have an eligible EE mobile plan such as Unlimited All Rounder, Unlimited Full Works, or Unlimited Essentials Plus, plans taken on or after 29 August 2024. Follow the instructions at Add unlimited EE data to your smartwatch
Alternatively, if you don't have an All Rounder, Full Works or Essentials Plus mobile plan, you can connect your smartwatch with a separate data plan for your smartwatch.
Hope this helps!
Ali
Ali_A
Hi @Lewisbaglietto
Hope this helps!
Ali
