on 20-07-2022 03:53 PM
I have a EE account and paired Galaxy watch4 which when on LTE will overheat after after about a 2 minute phone call.
The watch has been replaced same issue.
Has anybody else had the same problem or can suggest a fix?
on 20-07-2022 04:17 PM
@Teyford Do you have every feature turned on ? Making/taking a call will consume more power the more power consumed the warmer the device will get. It’s a side effect of a battery draining.
on 28-10-2022 12:15 PM
I have the same problem.
2mins into a call and it shutdown from overheating.
Why am I paying for esim if I can't make calls on it?
EE over to you...
on 28-10-2022 01:07 PM
Hi @Rb72,
Our Technical Support Team will be happy to look into this issue if you get in touch.
on 28-10-2022 01:28 PM
@Rb72 have you spoken to Samsung about about this as seeing as though they made the device and not EE. How long have you owned the device for ? When did this start ? Was it like this when you got it ? You might want to look at THIS
on 18-11-2022 02:25 PM
I have the same problem where the watch dips into emergency call mode if it deemed to be overheating. Unfortunately there's nothing that EE (or any other supplier can do) as it is a known fault with this watch.
