14-11-2025 12:39 PM
Hello!
I upgraded my phone to the iPhone 17 pro max on the 4th of November. The staff member in ee said it will be a 2 week wait. I haven’t received any sort of order tracking for it so im just wondering wether it will be sent the day before the phone is sent or what cause im just a bit confused
thanks! ☺️
14-11-2025 01:26 PM
@St3ph3 what colour and storage size did you order ? as there is different waiting times for each model spec of this device. Once the device is allocated to you you receive tracking information
14-11-2025 01:32 PM
Hi
I ordered the silver one with 256Gb
14-11-2025 01:36 PM
@St3ph3 on EE‘s website for this device and spec it states these are usually sent out within 14 days. you’re not receive any tracking information until the device is allocated to you because there needs to be a device to have tracking put against it.
14-11-2025 01:37 PM
So cause I ordered it on the 4th will it be sent to me on the 18th then? I’m confused
14-11-2025 02:20 PM
if it’s been 14 days on the 18th will I get info about the delivery on the 17th
14-11-2025 02:59 PM
Hello!
I upgraded my phone to the iPhone 17 pro max silver with 256GB on the 4th of November. The staff member in ee said it will be a 2 week wait. I haven’t received any sort of order tracking for it so im just wondering wether it will be sent the day before the phone is sent or what cause im just a bit confused
14-11-2025 06:37 PM
Welcome to the Community, @St3ph3.
Whilst you'll not get a tracking code for DPD until the handset is dispatched, you should still have received an order reference number starting with XK.
If you would like to get this double checked to make sure everything has gone through as it should do at our end, you can find the details on how to get in touch here:
Peter
