09-02-2026 09:33 PM
I’ve ordered a lilac iPhone 17 256GB yesterday morning and I’ve received the contract summary email and the contact number changed email but I’ve received no confirmation email and the only order reference number I’ve received on the contact number change email is 24 characters long and I can’t track the process (on the ee app)
10-02-2026 05:21 AM
Hi @Sj109
You'll need to speak to EE CS on 150 becase your may not be processed yet, then you can use EE order tracking
Download the DPD app as well.
10-02-2026 05:21 AM
Hi @Sj109
10-02-2026 05:39 AM
Thank you
10-02-2026 08:49 AM
Hi @Sj109
Just to add to @Northerner's brilliant advice,
I can see that the iPhone 17 256gb in Lilac is currently in stock.
If you'd like to get an accurate delivery time frame for your device, you can give us a call, and a guide can get this looked into for you.
Chris S
