Offer
Aleks4
Hello
i have a contract with EE IPHONE 12 pro and 40 GB DATA MONTHLY
AND I PAY 67£
can I find another offer cause I think i pay too much
Northerner
Hi @Aleks4
Have you text UP to 150 to establish if you can upgrade?
@Aleks4 : How & when did you order this plan? You can't downgrade to a cheaper plan mid-term, but only in your upgrade window from 45 days before end of term.
Can I upgrade only the phone
no sim
Yes, you can upgrade to new phone & plan & then use your existing SIM in it. You might be sent a new SIM just in case but you can ignore it if your old SIM fits.
no sim
The answer you've already been given is the correct answer, however if by "upgrade only the phone" you mean not taking a new 24month minimum term, then you can do by purchasing your chosen phone SIM-free.
Purchasing a phone from EE as an upgrade will mean a new minimum term contract.
