Delivery Address of Tech
Saz74
I'm not an EE customer & would like to order some bluetooth speakers. Can I have my order sent to my place of work as I dont WFH
Ali_A
Hi @Saz74
When placing your order online and continue to the 2nd step to the delivery address it will auto-populate with your billing address.
You can just press the "edit" button which will allow you select an alternative address for delivery.
Once you continue to the Terms of Sale page, it will show both the billing and delivery address you have entered.
Hope this helps!
Ali
@Saz74  If it allows you to put that delivery address in then yes.
Thats what I'm asking - is there an option to put a prefered or alternative delivery address???? the customer service number doest have options for advising on Tech purchases, when I finally did get through I was on hold while the call adviser said I'll ask my manager I was on hold for 30 mins then it cut off!
Ali_A
Hi @Saz74
Hope this helps!
Ali
