on 03-10-2022 09:54 PM
Hi we are going to the US and was looking at using the roaming pass. The account has three sim phone numbers on it, does the roaming pass cover all three sims or just the lead sim, the other two are shared sims on the account. The sim we want to use for roaming is one of the shared sims.
on 03-10-2022 09:56 PM
Hello @freezergeezer ,
Welcome to the community,
The roaming pass is only for one sim number, you would then have to purchase for all three numbers if you want it to work. Roaming pass has to be ordered for the one you want to use.
on 03-10-2022 09:57 PM
The Roaming Pass @ £11.40 pm is per mobile no. i.e. SIM.
The Roam Abroad Pass is charged pro-rata from the day you order it (text ROAMING PASS to 150) to the day you cancel it (text STOP ROAMING PASS to 150). You do start by paying up to the next bill date. Then in the billing month you cancel it you will get a rebate for the days after you cancel.
on 03-10-2022 10:04 PM
Thanks, doesnt allow for selection of roaming pass on shared sims, just to add minutes, 30, 60 and 120 and texts, assume will have to add these rather than a pass.
on 03-10-2022 10:08 PM
@freezergeezer , you will have to add roaming pass for each sim, then each of them can text and use minutes just like in the UK.
on 04-10-2022 12:10 AM
If a no. doesn't have the Roam Abroad Pass it cannot share the data of 1 that does when outside the EU.
