Roaming data add on
Laurenboone
I am trying to set up data roaming add on whilst in Australia and New Zealand however error message appears.
please could you advise?
@Laurenboone : Did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
