Roam Abroad Pass question
YiannisKyr
I have a plan which includes one smart benefit and i know i can change it every 30 days. My question is when I'm on holiday abroad i should switch to roam abroad pass which i will need it maximum 10 days. Is there a way to change it again when I'm coming back to UK? I think nobody is on holidays for a month.
Christopher_G
Hi @YianniesKyr
You can only change your smart benefits every 30 days. So if you change it before you go, it will cover the time period that you're away. Then after 30 days, you can change it back.
