Re: 120 mins from anywhere
sakshikarnwal
Does'120 mins from anywhere' add on includes India?
20 REPLIES 20
When I click on "Learn more" it takes me to a different page and I dont see any option to add the add on, can you please help urgently, I want to enable this 60 min add on for india asap
I never suggested "Learn More" but to slide it.
thanks, I did slide it, what shall I do after sliding it? only button available post sliding  is "learn more"? can you please try yourself
I did! I showed you what I get, 60 Global Roaming Mins.
is there any text I can send to enable 60 min add on? I am unable to do through website
@sakshikarnwal   Try it through the my EE app. Just click mobile add ons    Where is says Get more add ons just click it and select roaming and select what you want.
Thank you, I did install the app like you said, but it gives me only these 2 options, nothing for calling or receiving calls 😞
only data and text, no calling
@sakshikarnwal : Looks like your MyEE add-ons are just the same 2 that you can see in the Roaming Tool from there, missing the 60 Global Roaming Mins., unlike what we can see from UK where all 3 are present.
sakshikarnwal
60 Global Roaming Minutes, will this work in India? Can I take calls on UK number while travelling in India?
