25-05-2022 02:36 PM
Nowhere to order, nowhere to get info.
Someone needs to sort this
25-05-2022 02:49 PM
Do you already have a mobile contract with EE?
25-05-2022 03:33 PM
Yes, and I have the Nreal Air glasses but need some lenses +2.5
25-05-2022 04:39 PM
Hello @Templecloud.
Pricing and the option to add these to your plan can be found HERE.
The glasses are available to order and to expect dispatch within 14 days.
Katie 🙂
25-05-2022 04:47 PM
@Katie_J : I understand that the OP has already got these glasses but wants lenses for them.
@Templecloud : Just take your pair of Nreal Air AR glasses to the opticians and they should be able to fit your prescription lenses.
25-05-2022 04:54 PM
Thanks for spotting that @XRaySpeX.
@Templecloud the information provided above is correct, the opticians should be able to fit these for you 🙂
22-06-2022 04:36 AM
Just wondering do I just take the small prescription lens thing or the whole glasses? @Templecloud
22-06-2022 07:40 AM
Hi @Babyface786.
Welcome to the community.
Unless someone with experience of this can say otherwise, I'd recommend taking everything with you to be on the safe side.
Jon
27-03-2023 09:39 AM
In the uk, ive tried haf a dozen options and no-one does them.
On the web i found one company that does(lensology) them and they cost £95
Was too costly for me so i looked in websites in the us, since those glases are more common there.
Found that honsvr make them for $50 and ship to UK for free(takes about a week) so this is your best option if you are still looking.
I added a blue filter for $10 and still is much cheaper then the lensology which is based in the uk
27-03-2023 09:47 AM
You have two options in the uk. Order from lensology (uk) they cost £95 for lenses with frame or honsvr(us) cost $50 only lenses but ship to uk for free(takes about a week)
