22-09-2020 04:28 PM
How do I delete voice mail? I have a notification come up every time i boot up. its very annoying. the message has no content and my voicemail is off
Austen
22-09-2020 05:00 PM
Hi @Austpig
After listening to a voicemail, you need to press "3" to delete the message from your mailbox, this will clear the notification.
If you don't have any messages in there, I would suggest calling yourself from another phone and leaving a message that you can then delete.
22-09-2020 05:00 PM
Hi @Austpig
02-05-2021 01:07 AM
How to voicemail delete I try press 3 still no delete
02-05-2021 08:09 AM
Hi @Salam12,
Welcome to the community 🙂
When you chose this option on the voicemail menu, do you not have the option to delete? Or are you still seeing you have a voicemail after you have chosen to delete it?
Alex 🙂
