09-11-2024 04:17 AM
I have the same problem, i bought an EE eSim. When i try to text 150 it says "Not Delivered"
09-11-2024 08:12 AM
Good morning @redtissue.
Thanks for reaching out to us about this 😊
Where is it you purchased your SIM from, and are you in the UK right now?
Also is an EE signal showing when you look at the signal bars on your lock screen?
Peter
