24-09-2021 03:02 PM
Hi folks!
I've tried to check and fix it in my phone settings but it seems that is not the case. I have my phone for quite a while now and never had that problem before. What changed recently is I moved from EE contract to pay as you go. What is the problem?
All of the receving calls shows up as unknown numbers. Even my friends number which I have saved in my contact book shows up as unknow. Does anyone had that problem/ knows how to fix it?
Thank you
24-09-2021 03:44 PM
If you get in touch with our Tech Gurus on 150, they will be able to get this looked into for you.
Let me know how you get on 🙂
