roaming
Abdul1999
iam facing roaming on issue in pakistan anyone help me in this
Jon_K
Former EE Employee
Hi @Abdul1999.
Welcome to the community.
What issues are you having while Roaming?
Do you have a signal on your phone?
Jon
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
