13-06-2022 12:10 AM - edited 13-06-2022 12:11 AM
Whenever I try to send a regular sms message to people (I’ve messaged before ok) and I include a hyperlink or web address, it fails to send saying “not delivered”.
if I text them without any hyperlinks then it goes through fine.
I’ve reset network settings, turned mms off/on, turned sms off/on, restarted and hard reset the phone, tried with/without Wi-Fi and Wi-Fi calling.
Software version is current iOS 15.5 on iPhone 11 Pro Max.
iMessage is unaffected of course.
on 13-06-2022 08:10 AM
Hi @Priortothat,
Welcome back to the community. 🙂
If you are including a website link in your message, your phone may convert it into an MMS message. Have you enabled MMS messaging in your settings? If you don't have any MMS messages included in your plan, sending it will be chargeable.
on 13-06-2022 08:25 AM
I have indeed. I’ve enabled/re-enabled all related settings as you’ll see in my original post.
As for mms in my plan, I can only imagine it’s enabled as it’s a full fat iPhone plan and I call abroad a lot, so I can’t see why it wouldn’t be. Will call 150 but forget they only work limited hours which is silly, so couldn’t over the weekend.
on 13-06-2022 08:29 AM
Are you using a pay as you go or pay monthly plan @Priortothat
If pay monthly, do you have a spend cap on your account?
on 13-06-2022 08:36 AM
I’m on pay monthly. No spend caps or any restrictions that I’m aware of. I’ve not requested any anyway.
on 13-06-2022 08:49 AM
Hi @Priortothat,
Is there a spend cap showing in My EE? Go to Manage my device > Spend Caps to check.
on 13-06-2022 09:17 AM
I can confirm there are no spend caps set. Interestingly it’s showing up on my bill as a charge for a previously failed message that included links. I’ve been charged 61p for a picture message that failed to send.
13-06-2022 09:33 AM - edited 13-06-2022 09:33 AM
on 13-06-2022 09:42 AM
I can confirm there are no spend caps set. Interestingly it’s showing up on my bill as a charge for a previously failed message that included links. I’ve been charged 61p for a picture message that failed to send. Guessing I might need to call 150 to look through this in more depth.
on 13-06-2022 09:43 AM
It’s been 2 contacts so far. Neither have iPhones hence sending via sms, but I’ve not had to send web links to them before until now.
