connectivity in Toronto
Ham18
Hi. I am in Toronto having travelled from the UK. On EE network and I have the inclusive add-on of roaming. I am not able to have a canadian network signal although the carrier name shows on my phone. Completely cutt off unless I have WiFi connection and even with that I can not make normal phone calls.
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. You should always receive a welcome text message on first arrival, which doubles as a test of your ability to "roam" and receive SMS.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
