10-07-2026 09:44 AM
I have EE Pay As You Go SIM cards that I'm not able to use in the UK for an extended period (around 4 months) — I won't be making calls, sending texts, or using data on them.
However, I will be topping them up remotely (online) with around £8 every 2 months.
My question: does topping up count as a "chargeable action" that resets the 179-day inactivity/hibernation timer, even if I'm not otherwise using the SIM at all (no calls, texts, or data)?
I want to make sure the SIMs won't go into hibernation or be deactivated as long as I keep topping them up on this schedule.
Thanks in advance for any clarification.
10-07-2026 11:51 AM - edited 10-07-2026 11:56 AM
@Alex_St57 : PAYG SIMs don't go into hibernation until after 179 days (~6 months) of non-chargeable activity.
Topping-up during this period does count as a "chargeable action" & resets the period of inactivity back to 0, even if you do nowt else.
10-07-2026 12:24 PM
Welcome to the Community, @Alex_St57
As @XRaySpeX has mentioned here, it's only after 179 days of inactivity that your SIM will be placed into hibernation.
Even from then, you have a 3 month grace period to request the suspension be lifted, and it's only if you don't respond by the end of this window will the account be permanently cancelled.
We have a full breakdown of how this works here:
Understanding Pay As You Go Hibernation
Peter
10-07-2026 12:58 PM
Hi Peter,
Thank you so much for the clear explanation — really helpful!
I actually called EE Customer Support beforehand and was told that topping up does NOT count as a chargeable action, which left me quite confused. Your post clarifies things a lot, since it explicitly lists topping up as a chargeable activity (as long as it's done before the 179-day mark).
Thanks again!
