WiFi calling
Pah1966
Can anybody CONFIRM, if the recent doro phones do work with ee wifi calling, need a new phone for my mother to replace an old doro.
thank you.
The simple answer to "will xyz work" with an independently sourced phone is to try it. Make sure you have alternative arrangements and/or a returns arrangement, in case of negative results.
Is there a specific phone you're looking at? Either the model number or a weblink would be useful - someone can check.
@Pah1966  wi-Fi calling is account related feature and providing it’s enabled on the account. It should work regardless of the device because it’s just a Wi-Fi connection.  and the device needs the option for you to switched on.
Providing the correct carrier config is present.
The service is a WiFi-connection to the network's IMS server.
