WiFi calling
zedess
Good morning...have just enabled WiFi calling on my phone..when I use this will it use my data allowance (which I have tons of...but will never use) or my talk minutes (which I only have 250 of) and are very precious. Thank you
@zedess : It uses the mins allowance of your mobile plan & whatever data from your WiFi source, which if Broadband, is usually unlimited.
WiFi Calling is not a way of getting cheap or free calls but simply a way of routing them when the mobile signal is weak or non-existent.
354-
Star Contributor
Star Contributor
@zedess - WiFi calling uses the talk minutes. Take a look at your add-ons, you could add some more talk minutes too.
Thank you for the quick smart replys...I can now switch it off and get back to watts app!! Thanks again much appreciated
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Remember "calls" on WhatsApp are only possible between app users.
WiFi-calling provides an extension to mobile coverage, and works for any calls that you would otherwise make or receive over the mobile network. Calls to and from landlines being a prime example.
There's no charge for using WiFi-calling, and just means you can continue to use your phone for calls & texts when you might otherwise have no service,
