Voicemail
Tedrick
is there a way of turning off voicemail while you are in Canada or the USA without incurring text message charges? I know I should have texted VM off to 150 before I left the UK, but I forgot.
thanks
The most you can probably do is to set your conditional diverts away from the VM number, and hope the autodiverts don't kick in. I suspect they might.
Sending a text doesn't cost the earth & you only need to do it once.
I think you are probably right! I was just being mean!
