Voicemail
Jillyp31
Hey! Every time I try to access my voicemail it says calls to this number are barred. Anyone know how to fix this, or is there another number I can call to access my voicemail please? Thanks
1 ACCEPTED SOLUTION
You can contact voicemail on either speed-dial 1, or manually dialling 222.
Try texting VM ON to 150 to make sure your voicemail is enabled, otherwise you should contact EE C/S on 150 to check your specific account.
Leanne_T
Hi @Jillyp31
Thanks for coming here.
Are you in the UK?
Can you call all other numbers?
Are you dialling 1 on your phone's keypad to access voicemail?
Hey. No, I was trying to access it via the link on the text I got. Dialling 1 works. Thanks so much!
Jill
Thank you so much
Leanne_T
Great news @Jillyp31
Thanks for coming back and letting us know.
