16-12-2021 05:35 PM - last edited on 17-12-2021 07:52 AM by DanielPA
Hi guys,
Does it cost to listen to a voicemail note received from a 08438788319 while being on contact?
Kind regards
17-12-2021 08:01 AM
Hi @Abz101
Welcome to the community.
Listening to voicemails is part of your normal allowance. So if you're in the UK or an EU country that's covered by your plan, you won't be charged extra.
17-12-2021 06:34 PM
Hi @Abz101
Reading your post, it's perhaps worth adding some clarity to the answer you've been given.
It makes no difference what number a voicemail is from, as to what it costs you to listen to it. Your charges are based on the number you are calling from your phone, not who called you.
