Using phone in USA
Debbie1112
Hi, I’m on sim only and am going to the USA what add in is the best to get.
@Debbie1112  It’s the roam abroad pass at £25 per month.  You can then use your call and text allowance and up to 50Gb if your data allowance has this or more. Purchase this a day or two before your fly.   Don’t forget to cancel the pass when you’re back in the UK or you’ll keep paying for it.       Also text ROAMING to 150 to enable roaming on your account.  You should do this now as this means you’ll connect to a roaming network when abroad.   Please see THIS
Northerner
Hi @Debbie1112
To add to @Chris_B  comments you might already have this add-on benefit if you have an all rounder with an add on option you can change for free.
If not then it maybe more economic to upgrade to this plan.
