Using my mobile in India
Anne124
I’m travelling all over India for a month, from February 16.  Can I easily use my mobile in India?  What should I do before I leave the UK?
Any help much appreciated.  Thank you.
@Anne124 : Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/india.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have used your PAYG SIM to make a call or text in the UK.
