13-07-2022 01:28 PM
I am currently travelling in the USA and forgot to set up a roaming plan for calls and texts before I left the UK. Is there any way to do it from out here? I can't text 150 because I have no network access.
13-07-2022 01:33 PM - edited 13-07-2022 01:34 PM
@Cat76 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
