Unlocking my phone
Juliaapplegate1
I am in India and need to send and receive calls and messages while here how can I contact Ee to do this every angle is locked
Leanne_T
Hi @Juliaapplegate1
Thanks for coming here.
Do you wish to activate roaming or unlock the phone to use another network SIM card?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
What’s a CS number ????
Sent from my iPhone
To phone EE: Dial Freephone +44 800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & Home Phone.
