Ukraina
Mirowski24
I am in Ukraine, my phone is not working, please turn on the call
@Mirowski24  Is that contract or PAYG ?   Have you used that sim within the UK first?
 If on contract did you enable roaming by texting ROAMING to 150 ?
This is how I used the sim caste in the UK but I did not roam roaming
because I was driving the car and had navigation from the phone
@Mirowski24  Is it a contract or pay as you go sim ?
If on pay as you go do you have credit on the account to pay for call/texts ?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
