Turn on roaming while overseas
Matt1211
I'm currently in the middle east and I am unable to turn on my roaming. The EE website suggests I text 150, although obviously I am unable to connect.
All suggestions welcome.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
