Sms not working
Roland84
Hello my name is Roland im ouside uk at the moment and my sms card is not working can someone help me fix it
[Mod edit: Please do not share personal details such as your full name, as your posts are visible to the public. Thanks!]
Does your phone show a connection to any local networks in your host country?
Are you on PAYG or pay-monthly?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
