Roming
nickiordan
How to activate roming
@nickiordan : If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have already used your PAYG SIM to make a call or text in the UK.
These are separate from & necessary for any chargeable roaming add-ons that allow you to use your UK allowances abroad. Which, if any, add-ons will depend on where you you are going & whether you are on contract or PAYG.
@nickiordan  You text ROAM to 150.  This can be done anytime when in the UK as there is no charge to have roaming enabled on your account.
