Roaming
Lucymorris1986
I have set up an add on for roaming u limited. I am currently in Australia and it will not work. Please help asap
@Lucymorris1986 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
