Calls and data abroad
Sladen67
I have 2 mobile phones on my account my son has one in Amsterdam with him and he says it has run out of data etc and he can’t call or use WhatsApp I’ve added a free roaming abroad add on from ee but he says it hasn’t worked
Does your son's phone have a connection to any Dutch networks? Has his phone worked abroad in the past? Did your son receive a welcome text message on first arrival abroad? Assuming the answer to these questions is no....
